Hi all,
i need a speedo cable for a 1990 r32 gtst...
i'd appreciate any tips or help.
please reply or sms 0413 619 446.
Cheers
Man You asking for any tip or help.
Buy NEW ONE only from Nissan.Cost around 80 $.No worth to buy second hand.I paid my lesson with 2 ScH , they did last just few minutes so I wasted 2x30 $ for them and ended with new one anyway.
https://www.sau.com.au/forums/topic/250591-speedo-cable/#findComment-4342391
sorry to hear it, many thanks for the advice. looks like ill be buying a new one. appreciate it, cheers!
https://www.sau.com.au/forums/topic/250591-speedo-cable/#findComment-4348909
Well man , I got my lesson on my mistake.Some parts are OK second hand no prob , but some parts isnt worth to pay for second hand as they arent good , or dont last long so best investment is a new ones ,specialy when price isnt a big different .
Speedo cable is one of the part to buy new one as isnt expensive and effort to change it isnt worth to do job twice within few weeks , especially on hicas Skyline 's is a problem with steering if ur speedo cable is palying up.
https://www.sau.com.au/forums/topic/250591-speedo-cable/#findComment-4358726
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
