Hey all,
im having some problems with my car at the moment and want to buy a new car and have all these parts sitting in my room collection dust. i want to sell it all but if i cant ill keep it and put it together one day when i have more money.
GT3071R + actuator
it has a moddified ex housing to fit RB20/25 from GCG. A/R .50 .64 EX housing 14psi adjustable actuator. unused in box.
$1500
NISMO 600cc injectors
for RB20DET unused still in box.
$1000
Xtreme Clutch and flywheel kit
extreme motorsport clutch kit single plate hold upto 350rwkw 1600kgs clamping load and flywheel kit to suit.
$1500
HKS Cam Gears + HKS EX cam step 1 256
adjustable cam gears for RB20DET HKS 256 EX cam only for RB20DET still in transit not arrived yet.
$1000 (for both)
All items located in canberra. buyer is responsible for postage costs. pm, reply here or 0401 482 595. pics of cam not avaliable as yet. all items unused still in boxes.
Edited by RB ONEVIA
it all brand new, never been used. will make 250rwkw give or take. need a buyer for each item, its either all going or all staying.
surely someone needs this stuff. really need it gone as i dont have the time or money to do it. throw me some offers......
ive been informed that the injectors also will fit:
16600-RRR60 Purple 600cc
Nissan Skyline - R32 GTR - BNR32
Nissan Skyline - R33 GTR - BCNR33
Nissan Skyline - R34 GTR - BNR34
Nissan Skyline - R32 GTS-t - HCR32
Nissan Stagea - 25t RS Four (<98) - WGNC34
Nissan Silvia - S13 (CA18DET)
Nissan Pulsar GTiR - RNN14
Edited by RB ONEVIA
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
