I got vs-xx on mine
Nom nom nom.... f**k I miss seeing that out the front of work every day.... :)
Also try adelaide tyrepower, they can supply work/rays/SSR/enkei and other jap brands.....
Just beware with the Yen ATM you'll be taking an ass raping to buy new.
Try J-Imports on this site too, he has a lot of 2nd hand stuff.
https://www.sau.com.au/forums/topic/250949-work-wheels/#findComment-4347182
They look siiick ryan
Yeh the prices ive been quoted have been ridiculous, cheers to the financial crisis
If I could find some secondhand that were in good condition id be phyched
https://www.sau.com.au/forums/topic/250949-work-wheels/#findComment-4347225
Panzer they look sick man!
how much did u get em for?
I actually bought mine off ebay, cost me a total of $2k
The only place that i can think of atm that is able to supply them is ISC, hopefully this link will hep you.
http://www.isc-warehouse.com/index.php?mai...31f2782aa887534
https://www.sau.com.au/forums/topic/250949-work-wheels/#findComment-4347680
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
