Hi all I am thinking of selling my gtr. The car was bought with intent to use the car to promote our company, But have since decided to go in a different direction and could use the extra money although I'm not desperate to sell. Details are as follows
2000 R34 Gtr V Spec Bayside Blue
Blitz Nur spec Cat back Exhaust.
Blitz pod filters
Mines Air guide
I have recently fitted in last month.
New Apexi Power Fc ecu
New Nismo front and side indicators
New Apexi Gt Front pipe
Volk GT-N 18 x 10's +12 with Brand New Kuhmo 265/35 18's all round
Nismo 320 dash cluster
The car has 56 000km's on the clock. Also has all standard features like rear carbon fibre under tray. Driver, Passenger and srs airbags. Abs. Brembo's. Has been well maintained. I am also the first owner since it arriving in Australia. Car has always been garaged. It is exceptional with a few minor stone chips. I'm getting the car tuned within the next two weeks. Looking Around $58 000. No stupid offers or stupid comments. This is my price. Inspection Welcomed. No test drive unless i see cash.
Edited by OWN U
https://www.sau.com.au/forums/topic/251030-eoi-2000-r34-gtr-v-spec/
It had a driveline vibration. Had staggered wheels on it when i bought it. 18's front and 19's on the back and it damaged the transfer case so i just rather replaced complete box. Cost $4,500 for new box fitted. And that was with exchanging my damaged one. I say what happened is that when it landed someone changed wheels when imported.
The market has somewhat dropped and with the release of the new gtr it has most certainly affected the price on the 34's. Mine is a 2000 model and with more mods then most that are currently on the market and yet I have accepted and offer of $45,000. So I think that some indication of where the market is heading and what is to be expected.
A few more pics done today
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
