Oil, Oil Filter and spark plugs is what i would do. check your gearbox and diff fluids but they should be fine as long as they are at the correct level. Changing them out however would give you piece of mind as you would at least know what you have in them then.
https://www.sau.com.au/forums/topic/251053-serivce-kind/#findComment-4347224
Damn bro 29000 definabtly oil and filter change, does the engine sound ok on cold starts as in mornings? My r33 wasn't sounding the best, like knocking bcuz the oil became too thick so that when it started it couldn't suck up the oil quick enough, may be different on an r34
https://www.sau.com.au/forums/topic/251053-serivce-kind/#findComment-4350462
sounds really loud when starting the car in the morning but only for the first ten seconds i guess thats normal
https://www.sau.com.au/forums/topic/251053-serivce-kind/#findComment-4351322
i finally serviced my car last Saturday i did the following service and im having issues with 3rd and 4th gear it crunch's every now and then, the funny thing is it didn't have this problem before the service, what could it be?
engine= ROYAL PURPLE 10W-40
gearbox= REDLINE LIGHTWEIGHT SHOCK PROOF
diff= REDLINE 75W-90 HIGH PERFORMANCE GEAR OIL
also changed spark plugs and oil filter
Edited by Turbotonic
https://www.sau.com.au/forums/topic/251053-serivce-kind/#findComment-4377453
ร—
ร—
