Item
Black reclinable seats - Unknown Brand - Purchased off another user - Need the money for uni accommodation
Age
One run through the hills
Used very shortly in previous owner
Condition
Awesome!
No rips
No tears
Stitching in good condition
Very slight sun fade if you look very carefully, not noticeable in car
Price
I would like to see $400
Or would consider swaps for:
R32 GTR progressive spring and shockie set up
or perhaps something like SK's set up for 32 GTR
or Suede steering wheel of some sorts + cash my way
To Fit
R33 GTR/GTST
R32 GTR/GTST - May need to slot 1 hole on each rail by 1 or 2mm to fit
Location
Epping - Near Hornsby - Sydney
Contact
PM or here. Ill usually reply the same day
Additional Information
Has Seatbelt lock
Has seat rails that previous owner made
Drivers seats moves forward and back on rails
The shoulder pads and thigh padding can be adjusted in or out according to how big/small you are there are metal plates in the seat you can pull in or out
These seats are the closest thing I have found to a fixed back in reclinable form. Shoulder, lumbar and thigh pads are massive and just hold you in even full ball through the hills
Would not be selling these if I didnt have any other choice!
Pictures
More photos can be added upon request
Edited by GTS4WD
https://www.sau.com.au/forums/topic/251143-reclinable-seats-with-3233-rails/
whats difference between R32/33 rails to a R34 rail ?
you wouldn't want to swap for R34 GT/T seats aye.
how bad is the sunfade?
Umm.. to tell you the truth I dont know what the difference is.
Sunfade, well you can see it in the photos. Once the seats are in the car its very hard to tell.
Unfortunately man, nah, I need the money for uni..
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
