hey have the following for sale, just sitting up in my shed.
stock turbo working no shaft play! no actuator but can get one $100.00
aftermarket plastic grill insert, no mesh $20.00
3 inch silicon joiners, cut out of a common piece but good for straight joins. on piece still 250 long. $50.00
cooloing pro cooler for JJ, 300x300x76 $250.00
AVS Model 6 rims 4 stud 16 x 7 +32 3 are sweet, one has a repairable buckle $200.00 for all four
R200 diff. A1 condition 5 bolt shafts $220.00
Rb20DET gearbox great nick operating smooth in last car $400.00
RB20DET engine, bottom end baringgoing, 3/4 stripped on engine stand $200.00 comes with bits and pieces,manifolds, pipes.
prolly have some more gear ask me and i'll have a look
Located in S.A. North
Jarrod 0412 949 023
https://www.sau.com.au/forums/topic/251221-a31-parts/
