Few questions
Before that is it tig or mig ? Not sure, but I know little bit about this like letting it cool off and to tack a bar in place to reduce flex etc
1. We see this all the time on race cars to improve rigidity so has anyone done it? Any tips or tricks? Because I hear the chassis wi flex.
2. If we were to go to a professional to get it done what would the cost be? Say for just the front strut towers ?
3. There's a tig I've seen mentioned on an earlier post for about $560 would this be suitable.
4. If it is feasable and practical I may buy it and do my car just for fun to see what it's like, obviously you don't need much experience to spot weld inch on inch off. Would there be by probs other than flexing?
Depending on things I may be willing to help out fellow sau members but that depends on time taken to complete etc.
Let me know ta!
Edited by DaGr81
https://www.sau.com.au/forums/topic/251286-tig-welding-your-car/
hi bud.....
have you ever welded before..?? tig and mig a toatally different....if you buy a tig buy a gas regulator consumeables such as tugnsten tips nozzles and diffusers.....oh and a bottle of inert gas...argon...migs need gas aswell...or you can you a flux cored wire (gasless) just so you know you can get flux cored wire thats requirs gas too.....
inch on inch off is stiching not spot welding...
what are you hopeing to acheive?
what sort of driving do you do is it even worth the time money effort???
I see, I guess I'll be stitching then ^_^ improve rigidity for track use and I have used a welder in high school some 6 years ago, but if it helps I know I will do a quick course on it, basically just put stitches all over like strut towers etc I'll post up a few photos when I get home but yeah the whole idea is for improved rigidity and less chassis flex and flatter cornering etc willing to spend 560 on a welder to do this
ah i see...maybe it would be money better spent on good suspension , better sway bars spring shocks......etc
myabe i dont know....:D good luck with it anyways mate..i got a mig welder new off ebay for 290 delivered it works a treat....running gassless....i think it was from Geoffs Tools online store (ebay)
TIG will give u a nicer weld-presentation wise,& depending on the operator probably more penetration.
Mig is quick & easy but doesnt look as good as TIG.
& yes dont use gasless on your car it looks shitty no matter how good u r at welding.
shielded welding (gas) will alwyas give a nicer weld...and you can get a nice looking weld using gassless......dont know why everyone thinks gasless is so horrible
Hey mate tig is the go, and it will take alot more work than just the strut towers. I fyou really wont to gain something out of this you will want to weld almost every seam on the car in which case you will need to pull the windscreen out weld all the way down the join there the shotgun panels stich the underside of your car and so on, it's a big job if you want to do it propaly if your in melbourne outer east give me a pm and I'll come out and show you were you want to weld anyhow good luck....
Too bad I'm in sydney :P well I've got this rolling shell sitting in the back yard you see so I wanna slowly do all that prepare it for track fun... You think doing just the strut towers + the whole interior and boot will have any effect? Don't wanna start pulling windows out if I don't have to...
hmm just come across this thread and its exactly what i'm doing right now with my R31 skyline shell. TIG welding ALL (yes all) the seams and joins of the body. Though i'm only welding in the cabin area, as front and rear has strut braces going on. TIG is better than mig as it moulds the joins together rather than adding to them.
The only downside to welding most seams in your car, is you go through a lot of gas, and gas refills are around the $90-110 mark.
And yes, it is really easy to blow huge holes in the body if ya not careful.....practice on something first !!
I'll have to take pictures and post up my R31 body.
Few questions
Let me know ta!
ok i could write a whole page of dos and donts but short answers r
1 done 8 full cars and bits on i dont know how many cars .best trick is prep clean the surfaces back to bare metal then clean some more
seam sealer between the pannels is your worst enemy
you will only get flex if u heat the area to much
2 just the towers u say, if u do all the stripping n some prep around 350 if they have to strip ,prep,weld,seal,paint,around 1300
3 i would not use a tig i would use a mig some reasons are speed mig is much faster, n trying to tig upside down under the car is not easy
and it is easier to get the mig into tight places
tig is good for small jobs un less u have a fark off watercooled tig
4 heaps of othe problems if the prep is bad, fires ,chocking on smoke clouds , burns from boiling seam sealer splashing back at u
good prep will make a big difference
heres a few pics
More cost effective to diy, how come yours are spaced apart more than what I've seen on some map cars? Any noticeable difference in feel of the car? Rigidity? Flex?
i usually go in between spot welds as it is already welded on that spot as the name sugests.
it does make a difference but u wont notice much if the rest of your set up is lacking
if u do go to the effort then another thing u can do is around the door jams with a spot welder
new spot welds in between the factory ones
Mmm now to hunt down a mig ^_^ thanks alot for the great input guys once the funds are back up I'll start posting up pics, but first I need to add a boost cooler to my daily
i just bought a new 3 phase mig and want to sell off my gas/gasless SIP Mig if your keen.
similar to this item - http://cgi.ebay.com.au/SIP-Mig-Welder_W0QQ...106122001r15622
i payed $575 retail for it
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
