hey guys and girls
I currenlty have an 1994 r33 gts-t that i was thinking of using as a track car but have changed my mind and after putting too much cash into it,
would like to swap up to an R33-GTR.
have had the car for a year now and bought it as stock.
now has all the usuals,
car has a 1996 series 2 engine in it, just did its 100km service
R34 gtt turbo
Pod filter
FMIC
boost T, set at 10psi
3"-3.5" catback exhaust
Split fire coilpacks
Link ECU (not installed)
HD clutch
17" tri spoke advans + stockies
cage all ready to go into it.
Plus spare parts
havnt had it tuned yet but should be able to do 200rwkw, been told the r34turbo can handle a bit more than a r33 turbo.
i put 3grand into the engine when i first bought it, new head ect. and since then has been running great!
as stated in the sub heading paint isnt great, front panels are a home respray job but it adds character :D
asking 12 but will consider any resonable offers, and i would preffer to swap it plus plenty of cash for a R33 GTR.
thanks heaps everyone, will get pics up late tonight!
you can get me via pm, 0433971544 or [email protected]
Cheers
Gezza
https://www.sau.com.au/forums/topic/251330-1994-r33-gts-t-12000kono/
