  • Replies 70
Posted Images
it had a fmic on it and his number plates we 2JZ but i dont know, there was no bov and those things weight a fair bit but it was only on par with v6 commonwhores. We thought he was just a tool who had put badges on and bolted a FMIC in to look "cool"
A mate of mine has a 2JZGTE JZA80, with slicks and NOTHING ELSE DONE TO IT, it ran a 12.7 obviously with lots of practice :) We did have a sneaking suspicion that it came from Japan with highflowed turbos :( made 310rwhp off the boat!
Edited by bubba
https://www.sau.com.au/forums/topic/251396-heyy/page/3/#findComment-4353318
thank for ur help micheal i got a qoute today for a x force turbo bak zorst for 1450 is that a good and wat sore of power would i get
that is about correct, did it inc the cost of installing the exhaust?
because you already have a cat-back your better off just buying a front pipe and dump pipe as it will be alot cheaper (the cat-back section is the most $$ part of the exhaust)
here are few examples of what you could get and the cost
Stainless Split Dump/Front Pipes - RB20/RB25 - $269.00
Product Information
- Manufactured from high grade Stainless Steel pipe
- Stainless Flanges used at both ends (8mm Turbine outlet flange - 6mm Cat flange)
- 2.3mm wall thickness - 3 inch main pipe diameter
- Specially designed moon shaped wastegate divider
- Uninterupted exhaust gas flow through seperate of turbine exhaust and wastegate gases
- Factory 02 sensor screws straight in
- Guaranteed performance
- Guaranteed fitment
- Impeccable weld quality
- 12 month warranty
Link: http://www.skylinesaustralia.com/forums/St...on-t155238.html
Cooling-Pro Intercooler Kits - From $399.00!
COOLING-PRO INTERCOOLER KIT CONTENTS:
- Cooling-Pro Bar and Plate core, measuring 600 x 300 x 76mm
- Super strength JJR silicon joiners
- Race quality stainless hose clamps
- Mounting brackets, nuts & bolts (Where required)
LINK:http://www.skylinesaustralia.com/forums/Cooling-Pro-Intercooler-K-t138738.html
I just had a quick look and found those 2 items; but there is alot more stuff out their if you take the time to look. most of it can be bought from over-east and will be cheaper than buying it from a shop in W.A.
https://www.sau.com.au/forums/topic/251396-heyy/page/3/#findComment-4353410
I'm not going down again until the new turbo is on, I only went down last time to benchmark the mph which is why I didn't beat up on it trying to get a perfect launch/better time..
I'm more about going sideways than fast in a straight line heh
https://www.sau.com.au/forums/topic/251396-heyy/page/3/#findComment-4357460
has not been confirmed yet as getting numbers but i think they said sometime March or that could be when Drift pract at barbs Starts ha.
Will keep you posted :)
next couple of weeks im talin mine down who wants too come down and some time when i lauch it tramps is that normal
https://www.sau.com.au/forums/topic/251396-heyy/page/3/#findComment-4357726
    • Definitely a good “future upgrade” option if you plan on keeping the car and dialing it in even further.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
