Regarding that SR20 that they (ICE) tuned, did the car come with a Power FC and/or those mods? did they build it? Or did they just alter it to run on Australian Fuel? If they built that SR20 from scratch and tuned the FC to suit the mods, then they really know their PFC. However if the setting where already there and they just played/altered/adjusted them then its a different story isn't it?
Evan I was told from a friend in Japan that, witht the HC you can only access like 70% wheres with the software you can access 100% and with the laptop software you can also lock out what can be controlled from the HC and what can't. Meaning the laptop tune was a full tune and the HC is just a light tune.
xscape the Lap top software is only in Japanese I dont know of any one in australia that has it.
re the 300 rwkw sr it was bought with the hardwear but was tuned for .8 bar on stock injectors so they did the mapping.
They have tuned gtrs they have built up which are well over 300 rwkw.
meggala
BTW nice to see you here Evan
Originally posted by XSKAPE
I'm after a place that can do Laptop tuning
BTW: how much power were you making? at 4 wheels or 2 wheels and what mods?
Phu
everything else standard except for:
- 10 psi
- 3" cat back
- PFC
on the 23/01/02 @ ART 4WD dyno 180.2kw
on the 6/7/02 @ ICE 2WD dyno 180rwkw - additions are pods.
i dont think anyone in melb does laptop tuning... i thought it was just the convenience of tuning by laptop instead of the HC, but all options, etc are still the same?
Originally posted by meggala
Ice know their power fc's very well they tuned an sr 20 to over 300 rwkw with one and have tuned gtrs to well over 300 rwkw running power fc.
they know their stuff they are having a dyno day next saturday which makes it pretty cost effective.
meggala
Same deal as last time? in bayswater? and same price?
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
