+ 1 on brian, i bought my old moty van from him and the tint on it was also done by him, superb job, tint went below the
door trim so couldnt see the ending...
will also go as dark as you want, but i wouldnt recommend it on a skyline, sif cops need a another excuse.
https://www.sau.com.au/forums/topic/251459-mobile-tint/#findComment-4353281
My bro works for a tint company, he does mobile work. *edit* Just gave him a call, he said bout $250-$290 max. He lives south, so can probly do it pretty soon if you need?
I can give u his number, he said to give him a call
Edited by *flick*
https://www.sau.com.au/forums/topic/251459-mobile-tint/#findComment-4353437
didnt you see the part where he mentioned ''mobile'' ?
oh sorry, so the guy that came to my house and did my car must have been in my dreams then, try ringing around and being polite about what u want,its all about who you know. then everything could be mobile
https://www.sau.com.au/forums/topic/251459-mobile-tint/#findComment-4353990
Ah excellent - down South would be preferred!! I'll be in contact in say... 2 weeks? By then, I should be all ready for the tint.
Cheers!
https://www.sau.com.au/forums/topic/251459-mobile-tint/#findComment-4354064
Will any of the mobile guys do 5% Privacy tint? The places Ive rung wont touch it cause it's not "street legal" Cant see that mattering on a track car :3some:
Flick, can I have the number of your brother? Will he be able to do it? if not, anyone recommend someone who will?
https://www.sau.com.au/forums/topic/251459-mobile-tint/#findComment-4360336
Wow Ben, I thought most tint places would be happy to do it regardless if it's legal or not?! There's a Falcon around the corner of my place with the mirror-finish tint on all his windows except the front windscreen... it's crazy. You can only see in through the front windscreen!!
https://www.sau.com.au/forums/topic/251459-mobile-tint/#findComment-4360892
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
