G day
Ive just joined to read up on 32 gtr's as im planning on getting one.
I am currently driving a 95 civic hatch (eg5) with a b16a transplant running ITR b18c7 valve train, rolling on Apexi n1 coilovers. im also from the Ozhonda forums.
Looking forward to my time on the skyline forums :(
Regards Ken.
Heres some pics of my hatch. :happy: If anyone wants info on hondas im happy to provide whatever knowledge i have on hondas.
https://www.sau.com.au/forums/topic/252123-hi-all/
haha hey dude...welcome to the forums u sound just like i did when i joined here...i was from ozhonda aswell still got my 94 civic vti sedan....but got a skyline because some power is needed :( which my honda never could really give me
you'll find everything you need to know here im a noob on nissans but most of the guys here give great advice..
enjoy dude
https://www.sau.com.au/forums/topic/252123-hi-all/#findComment-4361528
yeh have already been reading the forums and theres so much info on here.
Im gonna keep the eg hatch for a daily and a r32 gtr for a weekend warrior.
hell yeah you should do that...my skyline has already broken down a couple times and the honda saved me from getting written warnings lol
https://www.sau.com.au/forums/topic/252123-hi-all/#findComment-4363717
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
