Small issue here
when my car is on the dyno the dyno wideband read 12-12.5afrs
but on my LC1 gauge it goes down as low as 10s at the same point
I have read many threads on the Innovate forums and they say this is normal
as the dyno has the sniffer in the tailpipe and that can make it read leaner
(my wideband is about 12" from turbo in the dump pipe)
this has me worried that if I was to tune the car to the afrs on the LC1 that would make it way too lean on a chassis dyno
basically what is accurate and what isn't
https://www.sau.com.au/forums/topic/252815-innovate-lc-1/
yes be very worried.
my techedge wide band is within .1 of a AFR with Hunter All Wheel Dyno's meter when running it up.
Your unit may need to be calibrated. I am not sure how to do it but if you ask around a few people have those, i think The Mafia has one.
You should take it back and get the local product Techedge, if you have ANY issues he sorts it out for you and can talk to you because he is local in australia and his service is second to none!
make sure your wideband is working correctly before you tune it or you could damage your engine.
https://www.sau.com.au/forums/topic/252815-innovate-lc-1/#findComment-4371940
Sounds like you may not have it calibrated correctly in the unit using the PC software. I had the same issue as it was using a 2v spread instead of a 5v.
Also, I had issues with the gas flowing past the sensor too quickly and the readings would freeze. I bought the tailpipe adaptor and it works great now. The delay is split second and you're tuner should know what he is doing anyway so it won't matter.
https://www.sau.com.au/forums/topic/252815-innovate-lc-1/#findComment-4371941
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
