hey guys
Cruise 1st of Feb - ALL CARS WELCOME -
Date: Sunday February 1ST 2009
Time: Meet up at 10.00 leave around 10.45
Where: Homebush P6F Carpark
Destination: Get to the Central Coast (Terrigal Car Park ) by lunch time get a feed at the fish and chip shop in Terrigal Haven then head onto Newcastle Forshore
Like i said before all cars are welcome LETS TRY AND GET AS MANY PPL AS WE CAN ON THIS!!!!
Posted on:
Street Commodores - Boost Crusing - Nissan Silvia
if your comming
Post Real Name / User Name / Make Model
Edited by lvnlow
https://www.sau.com.au/forums/topic/252993-homebush-coast-newcastle-cruise/
If its all cars welcome, wouldn't the cruise just be like driving up the freeway on any other day?
LOL - Pretty much!
Yeah I'll stay away from this, I remember there was a "insert club here" vs "insert club here" cruise and cops turned up, and douches trying to race each other
newy cops are having field hours at the moment.. since sunday ive seen groups of 5 highway patrols all together... saw them sunday, monday morning, monday arvo, this morning and this afternoon.... have also heard that many more people are actually getting done for dui instead of getting let through..
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
