Custom Coilpack Covers - Gb#5 - Rb20, Rb25, Sr20, Ca18
  • Replies 45
Posted Images
hey guys sorry for such a delay
Hello, do you have any more pics available of any other Nismo designs besides the ones already in the links in this thread? Im interested in a Nismo design just not 100% sure of what I want yet.
have a squizz through the previous group buy's mate, im sure youll find a few variations, or if you cant find anything you like just tell me what you want and ill get it drawn up :ermm:
can u make one with this design
cheers
julz
sending it away now to be drawn up :banana:
Yeah think i'm in for this one too,
still uncertain about the coils and water thing :(
let me know if you want to place an order mate :)
as for the water getting to the coils, its unlikely that a huge/damaging amount of water will ever get in there - even with no coilpack cover. but even so it just drains out the rear of the coilpack valley :) - happy to be corrected if im wrong! but there has been no complaints/feedback on this issue :banana:
Edited by Brycey
hey guys, sorry for the brief quiet period, there was some big contact delays between myself and AM performance due to the stinking great big heat wave down south, everything is back on track now and the GB will be extended from monday the 9th to monday the 16th, to make up for any lost time!
also now would be a good time to get in with your orders so there is no mad rush/delays at the rear end of the GB :P
:domokun:
Bryce did you receive the email I sent you with the design??? Might have something to do with the reason above but just let me know if you got it or not :geek:
sure did mate and has been replied to, sorry once again for that delay, i have been playing a bit of catch up this weekend! everything in Adelaide looks to be getting better so the group buy is back on track, but i hope everyone in Melbourne is fending ok!
:geek:
ending this coming monday (the 16th)!!
currently waiting on AM Performance to send me a few drawings for Cruzin33, Shenq, R33whitejeffo and Gunmetalgtr32
sorting an order out with ossie 21
reiterated interest from muz and drpheel
have received payments from bainator, stargate and rolex
also if you are still interested in placing an order then there is still plenty of time between now and monday (obviously) to get in, but please try and get all orders/payments in sooner rather than later so there isnt the typical week overhang of confirmations and waiting for payments to clear :D
if your name isnt in this post, then please pm me and chase me up! apologies in advance if i have missed anyone :(
have a good night! :P
Taso84 - just sent you a PM mate :(
group buy closes tomorrow night! still time to get in!
pretty sure everything is up to date, but once again chase me up if you have any questions!
:D
group buy closed!
still a bit of confirming and order collecting to do yet, but i will keep this topic updated for the buyers :):P
just a quick update, everything is well and truly under way, there was some overlap for delayed payments etc but everything is on track :D any worries then pm me or post up!
:P
hey guys sorry for not keeping this up to date, things have been a little frantic :P the covers are nearing completion but as usual the powder coated covers will take a couple of days longer. will write up when i find out more info :down:
last i heard mate production was finalizing, so i was under the impression that the packages would have been sent late last week, can only assume that this would be the week. ill try and get in contact and find out some specifics
all packages are typically sent registered, so once they are sent i will be able to get the codes for all you guys
:D
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
