The Mitsubishi GSR/EVO Club Present Round 1 of the Phillcom Rally Time Attack Series 2009. The event will be held 29th March 2009 at Mallala Motor Sport Park.
The Phillcom Rally Time Attack will be limited to ONLY 30 entries, positions will fill fast. Competition will be based on timed hot laps with ample opportunities to attain a personal best. No modification restrictions on entries.
Supporting local Tuner Houses, The Phillcom Rally Time Attack will be the basis for the Tuner vs Tuner Trophy! The perfect forum for Tuners to put their workshop prowess and pride on the line – Come see which Tuner House will take the title!
Trophies for ALL Classes, Tuner vs Tuner Trophy, and the Overall Winner of the Phillcom Rally Time Attack! This event is sure to please both entrants and spectators with the best drivers and workshop machines providing non-stop action!
Competitions must have a minimum L2S or L2SJ CAMS Licence and CAMS Car Club Membership to enter. Click here if you do not have these items.
All Tuner Houses and Businesses are welcome to compete in the Tuner vs Tuner Trophy Time Attack Series. Please contact [email protected] for further details.
Phillcom Rally Time Attack Round 1 2009
pdf-med.gifPhillcom Rally Time Attack 2009 Round 1 ENTRY FORM
pdf-med.gifPhillcom Rally Time Attack 2009 Round 1 SUPP REGS
https://www.sau.com.au/forums/topic/253133-phillcom-rally-time-attack-round-1/
  • 4 weeks later...
  • Replies 41
If anyone is worried about how their car will hold up, do not be too alarmed. The day aims to be fun and not overly stressful on the cars. Each hot lap is just that, one lap. The cars are only experiencing one lap of duress. Each competitor gets 4 hot laps per session. The first two hot laps the car should just be getting up to temperature leaving the last two for the more likely fastest laps. By restricting competitors to one lap sprints limits those race prepped cars on slick tyres etc, and brings up the street prepped cars into consideration. It is up to you how many laps you want to do, run a quick lap and sit back if you wish!
  • 3 weeks later...
Please nominate clearly AWD or RWD - you will be placed accordingly.
A few FDs entered to take on the nissans!
I'll be going AWD that's for sure. Will i need to have TOW stickers on the back of my car? my tow hooks stick out of my bumper, so its pretty hard to miss them. If i do where is the best place to get them?
http://cgi.ebay.com.au/CAMS-Approved-decal...A1%7C240%3A1318
i bought one last week for shits and giggles, looks like quality stuff and comes with a hard piece of cardboard so it doesn't bend :D
i think Luke said the OG speed shop sells them?
Autosport is currently under renovation, however Revolution Racegear may have them - about $10 for a sheet like above. Id expect the scrutineers would like to see them as precaution only. Your general safety items are essential.
pdf-med.gifPhillcom Rally Time Attack 2009 Round 1 FAQs
hey luke....do you wanna pick me up on the way mate
i am there to support the local SAU boys
Hey mate, that should be ok. Remembered the other night ive got some work to do on a S15 so i'll try and get that done Saturday so i can come Sunday.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
