Just a heads up guys, no this is not my car but it has come through my work (work at a motor auction)
Car is a white 1995 R33 GTST with alot of work done to it and i know it will be going for a great price!
Some of the mods include:
Autronic computer system
Full MSD ignition system with relocated coilpacks
Big top mount turbo on custom manifold
Blits blow off valve
Custom Performance metalcraft cooler
catch can
Turbo smart twin stage boost controller Looks to be running around 12 and 18 pound.
Full exhaust system
Huge external fuel pump
Surge tank
Fuel pressure regulator.
18 inch chrome wheels and lowered suspension.
There is probably alot more dont to the car that we dont know of but thats all I have noticed on a quick inspection.
Please call if you are interested
Cameron 0400 841 142
http://www.allianceauctions.com.au/as_vehi...amp;mvmta=95373
Inspecions are welcome but please call first.
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
    • If there's oil in with the clutch, I hope it finds its way out even if that hole has a cover/grommet 😛 I don't want oil near my cars clutch! 😛 Interested to hear the answer about covering it, I'm assuming a bung for a gearbox from another car that has a grommet to suit.
