Respray
Guest CleanAndSimple
First off ill apolagise for starting a new thread. :D
Recently been getting ever so more and more pissed off with bad blends here and there, and thinking about getting a respray.
questions are what price am i looking at?
thinking either full respray (body, engine, boot, cabin etc)
or
like shut door, considering im doing the same colour.
thoughts?
any idears on price?
and where does a good job?
https://www.sau.com.au/forums/topic/253273-respray/
  • Replies 65
If you are as picky as me, I'd be budgeting atleast around $8000 for a full respray. Means all windows come out, all new seals etc. Some good workshops around... All Type Crash I've heard good things about, I use and SWEAR by All Make Crash.
Had a very bad experience with one of the "big" workshops here in SA, I won't name them but I definately wasn't impressed with their workmanship.
End of the day, it all comes down to how deep your wallet is and just what you consider a "good job"
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4377429
How much money u got to spend?
Would u wanna sand back the car yourself?
resprays can range from 3k to 12k
My recommendation is Edwardstown custom body repairs if u got the money to spend. Or if u wanna sand it all back yourself my mate who works there might be able to do a cashy on the side.
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4377427
yeah 3k wont get you much these days, as with an old car like a 33 things are usually perished or very fragile when you remove them, and tend to break.
Even materials along cost abit, sand paper, prepsol, primer,paint,clear, nuts/bolts everything has to be taken into account.
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4377436
Like Luke said, for 3k you won't get much... My saying is, if you are gonna do it, you might as well do it properly. Imagine how pissed you'd be spending 3k only to get a finish you aren't happy with?
Money down the drain isn't it, and back to square one
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4377442
do you really need a respray or a really good detail? I'd be willing to give it a go cheap if the paint isnt destroyed already? save you a bunch of money, I redid mine after I priced the respray...lol and I'm picky ..lol
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4377516
old car?33? lol your car's only 2 years younger than mine. hehe bite your tongue
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4377654
Although I haven't had any experience with them Tom Howard did a good job of colour matching the orange/gold pearl when Flick got the fibreglass guards painted.
Tom Howard did a good job colour matching part of the underbody with my side panels ;)
and All Type Crash... I'm not too keen on going back there.
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4377705
i wanna get my dato done but im fearing the figure theyll throw after seeing the rust n bog areas :blink:
anyone know a apprentience painter that needs a practice car? i dont really care if the dato's not perfect aslong as it doesnt fall apart from rust :P
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4378038
This is from another thread, im to lazy to re-write it :blink:
If you are after a full respray its gana cost you around 8-10k. If you take out the motor and interior and prep that in 2pac primer it will be around 5k. If your good with a spray gun i would paint the engine bay,cabin and door jams in the colour you want and that will be around 2-3k to finish the job. If your good with body work i would take it further and prep the outside in 2pac primer and that will be around 1k to paint the outside.
these are prices from some of Adelaide best places
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4378133
Don't think he does powdercoating ... not that I was aware he had the equipment.
Looked at that link, the map is slightly incorrect. His 'shed' is at the right hand bend of Chapman Road on the left ... furthest shed in the corner of the lot. There is a chroming specialist next door to him. One stop shop :P
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4378665
he powdercoats rims too doesn't he Ruby?
http://www.yellowpages.com.au/bi/daniel-st...sa-5608307.html
No he doesn't, but he does a good job of painting them, im very happy with the way my rims turned out :laugh:
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4379995
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
