Respray
Guest CleanAndSimple
First off ill apolagise for starting a new thread. :D
Recently been getting ever so more and more pissed off with bad blends here and there, and thinking about getting a respray.
questions are what price am i looking at?
thinking either full respray (body, engine, boot, cabin etc)
or
like shut door, considering im doing the same colour.
thoughts?
any idears on price?
and where does a good job?
https://www.sau.com.au/forums/topic/253273-respray/
  • Replies 65
If you are as picky as me, I'd be budgeting atleast around $8000 for a full respray. Means all windows come out, all new seals etc. Some good workshops around... All Type Crash I've heard good things about, I use and SWEAR by All Make Crash.
Had a very bad experience with one of the "big" workshops here in SA, I won't name them but I definately wasn't impressed with their workmanship.
End of the day, it all comes down to how deep your wallet is and just what you consider a "good job"
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4377429
How much money u got to spend?
Would u wanna sand back the car yourself?
resprays can range from 3k to 12k
My recommendation is Edwardstown custom body repairs if u got the money to spend. Or if u wanna sand it all back yourself my mate who works there might be able to do a cashy on the side.
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4377427
yeah 3k wont get you much these days, as with an old car like a 33 things are usually perished or very fragile when you remove them, and tend to break.
Even materials along cost abit, sand paper, prepsol, primer,paint,clear, nuts/bolts everything has to be taken into account.
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4377436
Like Luke said, for 3k you won't get much... My saying is, if you are gonna do it, you might as well do it properly. Imagine how pissed you'd be spending 3k only to get a finish you aren't happy with?
Money down the drain isn't it, and back to square one
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4377442
do you really need a respray or a really good detail? I'd be willing to give it a go cheap if the paint isnt destroyed already? save you a bunch of money, I redid mine after I priced the respray...lol and I'm picky ..lol
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4377516
old car?33? lol your car's only 2 years younger than mine. hehe bite your tongue
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4377654
Although I haven't had any experience with them Tom Howard did a good job of colour matching the orange/gold pearl when Flick got the fibreglass guards painted.
Tom Howard did a good job colour matching part of the underbody with my side panels ;)
and All Type Crash... I'm not too keen on going back there.
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4377705
i wanna get my dato done but im fearing the figure theyll throw after seeing the rust n bog areas :blink:
anyone know a apprentience painter that needs a practice car? i dont really care if the dato's not perfect aslong as it doesnt fall apart from rust :P
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4378038
This is from another thread, im to lazy to re-write it :blink:
If you are after a full respray its gana cost you around 8-10k. If you take out the motor and interior and prep that in 2pac primer it will be around 5k. If your good with a spray gun i would paint the engine bay,cabin and door jams in the colour you want and that will be around 2-3k to finish the job. If your good with body work i would take it further and prep the outside in 2pac primer and that will be around 1k to paint the outside.
these are prices from some of Adelaide best places
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4378133
Don't think he does powdercoating ... not that I was aware he had the equipment.
Looked at that link, the map is slightly incorrect. His 'shed' is at the right hand bend of Chapman Road on the left ... furthest shed in the corner of the lot. There is a chroming specialist next door to him. One stop shop :P
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4378665
he powdercoats rims too doesn't he Ruby?
http://www.yellowpages.com.au/bi/daniel-st...sa-5608307.html
No he doesn't, but he does a good job of painting them, im very happy with the way my rims turned out :laugh:
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4379995
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
