Hi all,
been wanting a new set of wheels for a while now, finally got the funds together. Its for my S2 R33 2DR. They are DTM Z7 18" alloys;
Got no idea on offsets.....This is whats available; I like the wider rear width look. Please help. cheers
5x114.3 stud pattern
18 x 7.5 +30 offset
18 x 7.5 +40 offset
18 x 8.5 +30 offset
18 x 8.5 +35 offset
18 x 8.5 +38 offset
18 x 9.5 +35 offset
18 x 9.5 +40 offset
18 x 9.5 +45 offset
https://www.sau.com.au/forums/topic/253371-dtm-z7-18/
Thankyou for your opinions guys.... I dont know very much about wheels, the Z7's were one of the first lot that actually looked like they suit the car for me.
Looking online, i found the DTM site, but could not see the Z7's in there at all??
http://www.dtm.co.nz/wheels/view/brand/2/dtm/
Anyway, i really liked the DTM Kaliber, much better than the Z7's in my opinion (http://www.dtm.co.nz/wheels/view/wheel/70/dtm-kaliber/)
thats pretty much the style i like and am interested in getting, doesn't necessarily have to be DTM, any suggestions on other makes with similat styles?
18x8.5 F, 18x9.5 R is my preference.
Thanks is advance!
https://www.sau.com.au/forums/topic/253371-dtm-z7-18/#findComment-4380576
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
