nah gtst wont fit.
The gtr guards are fatter.
I had same problem after changing gtst to gtr guards..... all the little things that I hadnt thought about before I decided to change the front end....
Nissan have them brand new, I think I payed around $200, but that was just on 2 years ago.
Will
yeah mate u'l need..... guards, guard liners, indicators, gtr front bar (gtst wont fit) , gtr bonnet (to match bar), new bonnet latch and bracket, budget for 25mm bolt on spacers for wheels ( bout $4-500, normal plates spacers and giant studs may work but a bit dodgy) unless u can get gtr wheels, but unless u do back, u wont have matching rims, and gtr rear wheels are too fat with gtst guards. Ull need new side skirts gtst wont fit, unless u modify em a bit.
So pretty big job.. but looks cool.
Dont think theyr are too many that have done the whole job. But after u add up the costs ( i did mine all original), even though parts are a bit cheaper now, an 89 GTR would b very close to the price after selling ure own car. And then remember a front end respray so they all match and a blend into the doors.
Will
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
