The time has come to sell my baby, where I'll be moving doesn't have secure parking so I've decided the time has come to sell my pride and joy.
93 GTST.
Mods:
18" rims
trust front bar
impul r34 side skirts
impul r34 rear bar
drift lip wing
custom red
series 2 engine
blitz front mount
blitz neuro spec V exhaust
kkr Turbo
dual stage boost contoller
walbro fuel pump
Nismo fuel reg
splitfire coils
blitz BOV
apexi safc 2
bee*R Rev limiter
dyno proven 250.2kw at the rears
Apexi Coil overs
2 way lsd
rda slotted rotors
ferodo ds2500 pads.
Complete package one of the tidiest examples around, goes well, handles well, stops well you can't go wrong!!!
Car is currently in sydney but has ACT rego custom plates "Y TR1 33" plastic slim line black and white
Chasing $19000 o.n.o
pm
or
0420 243 038
cheers
https://www.sau.com.au/forums/topic/253547-250kw-r33-gtst-very-nice-looking/
How many KLMs has it done.
Good looking car but not in my price range ......
the car has done about 160k but the motor is out of a series 2 and has only just done just over 100k. The original motor let go after a mechanic installed a link ecu and turns out he mustn't of know how to tune it too well because 1 week later 1 and 2 cylinder leaned out and the motor let go. So new mechanic all work was than done by trojan performance and the safc went in. Turbo has done about 5k and clutch which is a custom built 1260kg brass button has done about 2k. All up when the motor was changed and turbo etc. $10000 was spent at trojan. She pulled 250.7 kw on 16psi, pulls 241kw on 14psi with a really smooth power curve makes full boost at around 3500.
and as for price feel free to make an offer you don't know unless you ask i guess.
also note front bar does has a small crack on side and one down the bottom can get it replaced for approx, $500 painted and fitted as the car is used by J Racing in canberra to advertise the trust front bar
http://www.jracing.com.au/product.php?pid=101
Edited by Darkon
okay maybe $19000 is to much with the lovely decline in prices
$17000.00 ono
still not as low price as some but this car has look I believe that is hard to match which makes it worth it. It is a regretful sale it's been 6 great years my heart just isn't in it anymore so why not let some one else enjoy it.
But i guess hey if no one wants it I'll just keep it
cheers
still no offers!!!
going on deployment in June so I want this gone!!!!!!!
will also swap for a Kawasaki or honda 250 (zzr, GSR etc.) plus $10,000
Edited by Darkon
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
