  • Replies 58
I am getting my R32 this weekend and am keen to test her out. So count me in please.
Let me know any details or whatever at: [email protected]
We need to do this kind of stuff more often.
Like track days and everything.
Sounds good and cheap to me,
Thanks.
Eddie
lol! you certainly do need a sump baffle, otherwise you may suffer SBS.
Actually, skid pans are a really easy day on the car. You get bugger all tyre and brake wear which is *very* different to a full track day.
No helmet required, will probably need long clothes.
Fatz organised one about 6 months ago and it was *top* fun.
yea that laack day cost me about 500 but shit it was fun
just keep saying the word drift and lots of non track day pleople will come out dont mention the skid pan or they wont turn up
maybe we should get a company to sponsor the day that puts in sump baffels.... they will make a fortune
pete
20 people so far. 20 More to go.
Fatz, You can pay $100 and do both the AM & the PM.
We can have 20 people $50 9am -1pm & then 20 people $50 1pm - 5pm. You get the same amount of time, just less wait between goes.
Im in for any kind of drift day, imo Not enough of them in NSW
this question might sound stupid, but what kind of drifting is there to be had on a skid pan. Will there be courses marked out with witches hats or something.?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
