Well firstly, I noticed my Oil temp gauge yesterday go higher than normal and then today I drove the car for 5 mintues and my upper radiator hose burst and spilt coolant all over the place. Replaced hose with a new one and replaced 5ltrs of coolant. Drove car again for about 10min and there was hissing from the engine bay again and noticed that all the coolant had begun pissing out again, this time it seems from a hose near the back of the engine??
Is this a radiator issue, thermostat issue, head gasket:( or something else??
Can anyone help?
Appreciate it
JG
Hey man I just notice the same problem yesterday on my GTR 32, it seems like it's coming from the rear of the engine.
Its only a small amound of leak through.
Is it a hose issue???? how did u fix yours???
Thanks
Chris.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
