Hey Y'all.
Taking the 'R for a bit of a cruise this coming weekend, Driving to Lismore, then on Saturday and Sunday arvo/nights I'll be in the gold coast/brisbane.
Anyone keen to meet up? (Saturday is the best night, Sunday i'll be a tad busy).
Christian
https://www.sau.com.au/forums/topic/25413-fo-shizzy-prizank-in-da-hizouse/
Originally posted by PranK
heh... i like that! ;) :headbang:
I was hoping you wouldn't get offended!
We'll just be doing the normal Gold Coast thing. If you want to ring me to see where we are, it's cool.
Broadwater carpark is directly across the road from Australia Fair. It's a big bitumen carpark that has about 1000 car's in it on a saturday night. I'm sure if you just get on the Gold Coast Highway and head north, you'll see most of the cars turning into there off the main road. We normally don't reach the carpark till about 9/9:30 once we've stopped at a million servos!! :rolleyes:
Let me know :(
Prank - Me and some others from SAU are hitting the booze in a major way on saturday night. 0411870159 if you want in. House Party.
Sunday morning we are having a very hungover dyno day. $20 a go.
Gimme a call either way.
Suck the Booooze!
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
