Hi guys I have a 1990 R32 GTR gathering dust over in NZ it was pre modified in Japan and I have owned it for over 1 year there and have been in Au for over 2 years. When they say ownership overseas for more that a year for personal import does this car have to be registered in the country of origin during this ownership? As my car was non compliable in NZ and therefore not registered … but legitimately owned by myself, and dose GST still apply considering I’m not selling or buying the item?
I guess I could bring it in though sevs etc but due to the mods it would end up to much work to make standard and I may as well sell there and cut my losses and sell it there.
https://www.sau.com.au/forums/topic/254178-importing-from-nz/
Because you didn't have it registered there, I think you're going to have a hard time bringing it in as a personal import. And yes you'd still pay GST on it if you did bring it over.
Actually, when was the purchase date in Japan? (Presuming you imported it to NZ yourself)
Edited by Iron Chef
Hi guys I have a 1990 R32 GTR gathering dust over in NZ it was pre modified in Japan and I have owned it for over 1 year there and have been in Au for over 2 years. When they say ownership overseas for more that a year for personal import does this car have to be registered in the country of origin during this ownership? As my car was non compliable in NZ and therefore not registered … but legitimately owned by myself, and dose GST still apply considering I'm not selling or buying the item?
You need to be in NZ with the car. I have just got my car here and had to give complete scan of passport and account for all time out of NZ.
Lucky I have owned the car for 6 years and was in NZ for 14 months.
Also needs to be registered so not much chance of the personal import rule working for you.
Edited by Waza_GTR
  • 1 month later...
Bugger I was hoping this would not be the case it too good to part out but I guess thats to only option bar a race car ....
Cheers Guys
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
