I got this turbo to use for drifting, but now i realised I needed the money for something else.
Its about 12 months old but was only used for about 8 months, was removed from car to upgrade to gt35r
Looking for $1200 ono, this is a external waste gate turbo.
https://www.sau.com.au/forums/topic/254188-gt3040-82-rear-housing/
  • 4 weeks later...
  • 2 months later...
  • 4 months later...
  • 1 month later...
