For sale rb30e series 1 block with all internals minus everything on outside $75 or swap for something that I need that is listed or interested in
Perfect for 25/30 conversion
for sale rb30et head $50 or swap for something that I need that is listed or interested in
pics up soon just want it all gone
or will swap for parts of interest let me know what you have got
Item: r33 series 1 wing
Condition: great no damage
Price: $50 or swap for something that I need that is listed or interested in
To Fit: (What car) r33
Contact: josh
Comments: removed to fit series 2 wing
will post at buyer expense
Item: r33 stock intercooler only no pipes x2
Condition: good
Price: $30 each or swap for something that I need that is listed or interested in
To Fit: (What car) r32, r33
Contact josh
Comments: only removed to fit FMIC
Front pipe
Condition: good
Price: $20 or swap for something that I need that is listed or interested in
To Fit: r33
Contact josh
Comments: removed to fit 3 inch split dump pipe
Will swap for r33 gtst parts like steering shroud,
the plastic bits the go from roof to floor in the middle of the car
all boot trim
parcel shelf
drivers side door trim and passenger side
handbrake rubber thing gearstick boot gear stick plastic
pretty much any interior parts let me know what you have and we can work something out
clear side indicators or smoked ones
turbo timer
stock 33 5 stud rims
33 gtst indicator stork and the little box on the end of it
also need an r32 rb20det wastegate in good condition but must be in perfect working order
decent battery for r33 gtst
top half of the r33 gtst plenum and crossover pipe
hks ssq blow adapter so it will bolt straight on to where the on goes
aftermarket front for r33 gtst series 1 will pay extra if needed need asap something like trust or 400r or gtr style it can be a little damaged but not to much
pics up as soon as i find the camera cord
https://www.sau.com.au/forums/topic/254339-parts-for-sale/
Contact: josh
Condition: good
Contact josh
Front pipe
Condition: good
To Fit: r33
Contact josh
all boot trim
parcel shelf
turbo timer
thats a bit easier to read
Edited by Turbo 33
https://www.sau.com.au/forums/topic/254339-parts-for-sale/#findComment-4392076
  • 3 weeks later...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
