If you all think the doggies are gunna win today then how bout Doubling your money eh??
Ive actually given myself a good chance of gettin $10, i put $10 on the dogs, and bet a mate $20 that the roosters would win, so either way i stay even, and if the roosters win i get $10 =D.
