EEEK..ONARUN is sold?
Guest | hype^ |
yeh congrates 2rismo, i bet your lovin it..!!
and yeh go the mighty red devils! :lol:
yeh george, so your getting a mustange ay.. very nice..
if sum1 would be nice enough to point me towards a pic of this ride id appreciate it.. :P
you still gonna stay involved with the club george?
too bad i didnt get a chance to go on another cruise with ya man.. :D oh well..
https://www.sau.com.au/forums/topic/2547-eeekonarun-is-sold/#findComment-46443
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
