My much loved 34 is up for sale as i can no longer justify keeping a car that only gets driven 3-4 times a year.
R34 Gt-t skyline, 5 speed manual, RB25t (neo 6) ,17 inch prodrive wheels with good tyres, tien adjustable coilovers, jap cat back exhaust, splitfire ignition coils, adjustable boost, blitz turbo filter, front strutt brace, tinted windows, pioneer cd player, climate control, power steer, 4 wheel steer, traction control (on off button), electric windows, anti-lock brakes, central locking, dual airbags, power mirrors. Meticulously looked after, always serviced with full synthetic oil, always garaged and under car cover. regd till feb 09. must sell $27000 , Bellbird park 0427467779, or email [email protected]
post-44110-1233567649_thumb.jpg post-44110-1233567731_thumb.jpg post-44110-1233568410_thumb.jpgpost-44110-1233568449_thumb.jpg
https://www.sau.com.au/forums/topic/255271-r-34-gt-t/
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
  • 2 months later...
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
