I don't think I'll be doing Superlap now Troy, I'd rather do PI on the following weekend and can't afford to be doing both. I also don't want to get to NSW with no testing time and have issues with the car, which is sure to happen if it is its first outing.
I guess it depends if it's finished early or not...
That is my concern, i have not tracked my car since October 2007 and using my last international flight to come back to Aus just to blow up a car because i have not had a chance to put some kms on it and check everything....yeh its a concern. But if s little something comes off i will be there with bells and whistles
