Twin t51's It would be laggy as all hell..
They usually get 700+HP out of a single t51!!
10K Mods? Assuming the GTR is stock, I would go for Full exhaust, Air Filter, Adjustable Cam gears, High flow the turbos, Power FC, Stonger Clutch, Boost controller, pump / Injectors etc - That should set you back 10K and give you over 230KW atw at 14psi.. (Tuned properly)
Good luck with the buy... R34 Gtr's are as rare as rocking horse shit (In the ACT)
There are quite a few 34 GTT's going around.....couple of silver one's (some 4 door), a yellow, couple of black and a white one with what looks to be a carbon fiber bonnet (very schmick!) I don't know of any 34 GTR's going around. There hasn't been any on display in either of the two main import yards. If you end up getting one it would certainly be in the 'very-rare' category.
the idea of having twin t51r's is they spool up quicker, and having such big turbos will give u lotz a power
alot of the top jap drag gtrs have this setup
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
