Twin t51's It would be laggy as all hell..
They usually get 700+HP out of a single t51!!
10K Mods? Assuming the GTR is stock, I would go for Full exhaust, Air Filter, Adjustable Cam gears, High flow the turbos, Power FC, Stonger Clutch, Boost controller, pump / Injectors etc - That should set you back 10K and give you over 230KW atw at 14psi.. (Tuned properly)
Good luck with the buy... R34 Gtr's are as rare as rocking horse shit (In the ACT)
There are quite a few 34 GTT's going around.....couple of silver one's (some 4 door), a yellow, couple of black and a white one with what looks to be a carbon fiber bonnet (very schmick!) I don't know of any 34 GTR's going around. There hasn't been any on display in either of the two main import yards. If you end up getting one it would certainly be in the 'very-rare' category.
the idea of having twin t51r's is they spool up quicker, and having such big turbos will give u lotz a power
alot of the top jap drag gtrs have this setup
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
