  • Replies 108
Posted Images
does anyone no wat time u will be meeting at the truck stop if ur still meeting there
12pm - time /distance to truck stop x speed +10.
12:30ish? no idea.. how long it take from p6-> truck stop?
thanks for speedbump advice for those low boys :P
ill be taking the most direct route after old pac, ill just tell my GPS where to go and anyone who doesnt care about their bodykit can follow me :lol:
Edited by illusiVe
You're looking at 30-40 mins.
There are 2 main routes you can take. 1 is to follow Homebush Bay drive onto Devlin St onto Lane Cove Rd all the way to the Pacific Highway. Turn north until you hit the F3.
The other is to turn off Devlin St onto Blaxland Rd. Connect up with Epping Rd which turns into Beecroft Rd and then right onto Pennant Hills Rd. That eventually puts you onto the F3 as well.
After Pac there's only 1 real way to The Haven, so everyone should be going the same way. All the way through Gosford, basically.
Getting dressed now.
drove out to auburn officeworks then to P6 with a few of the SAU boys. got to donate but didnt end up going to terrigal. started pissing down. was good to meet a few ppl though. just went and got some KFC with them.
bloody rain. every time i stepped out, it started to rain slowly...then pissed down when i wanted to go somewhere.
hey raf you up to go Oran Park next Sunday to watch drifting....shehan saaid he's up for spectating too.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
