Macguyver Boxed Dvd Set 39 Dvd's 139 Episodes 2 Movie Special Features.
Macgyver Complete Series Collection On 39 Discs Containing All 139 Episodes + 2 Movie Episodes Made For Tv Never Released New & Factory Sealed In Region 1 (NTSC)
This Set Will Require A Multiregion Player That Is NTSC Compatible as this is only sold in the U.S
Not Available In Australian Stores, Purchased from the U.S
Macgyver : Complete Series Collection Box Set (39 Discs)
Seasons 1,2,3,4,5,6,7 (Seven Being The Final Season) Of Macgyver On 39 Discs Containing A Massive 139 Episodes! + the 1994 made for TV movies "Lost Treasure of Atlantis" and "Trail to Doomsday."Only In this Box Set!
Using his brain in place of a gun, secret agent Angus MacGyver (Richard Dean Anderson) relies on his knowledge of science to save himself and others from jeopardy.
Deploring the promotion of everyday violence, MacGyver refuses to carry weapons and instead designs lifesaving tools out of household staples like paper clips and duct tape.
Anderson portrays a likeable hero of strong principles and intellect in this clever series, which successfully ran for seven years and continues to remain a beloved cult favorite.
This collection presents the series in its entirety.
Product Details:
Screen:
Fullscreen
Audio:
English Dolby Digital Mono
English Dolby Digital Stereo
Subtitles:
[None]
Running Time:
6623 Min's (110 Hours 38 Min's)
Details:
$165 Delivered
The set is obviously used though all discs are perfect and box in good condition.
Any old school MacGuyver fans dream.
I have been through the whole set twice and watched everything to be seen. The time just gets away from you when you sink into it :( I am not allowed to watch them anymore, the other half just doesn't understand the MacGuyver way.
Same as all other sales:
__________________________________________________
Account Details:
Account Name : SLIDING PERFORMANCE
Account number : 034169026
BSB Number : 484799
Suncorp Metway
Please use your SAU user name as the transaction reference and provide your full name and delivery address.
If you do not list your user name this will extend processing time.
PayPal payments are accepted though must include a 2.6% surcharge to cover fee's on top of the items total : [email protected]
  • 5 months later...
can i offer you a piece of chewing gum, some string, and an aluminium pipe? makes a bazooka apparently :D
please sell this before i get my hands on some cash!! :)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
