Having a clean up to in order to move. PM me if you have any questions.
I am located in Burnie, Tas
Standard R34 GTT FMIC
No damage - removed for FMIC fitment - Includes factory pipe pictured
$140
Standard R34 GTT Wing with East Bear Pillars
Great Condition - Removed for shaved boot - Painted Jet Black - Fully adjustable- Made From Aluminum
$220
post-48970-1234689349_thumb.jpgpost-48970-1234689383_thumb.jpgpost-48970-1234689412_thumb.jpgpost-48970-1234689514_thumb.jpg
R34 GTT/GTR East Bear Bottom Eyelids
Like new condition - ABS Plastic - Painted White
$80
R33 GTS-t Series 1.5 Turbo
Very Minimal Shaft Play - Removed from engine with 33,000Klm's - Removed due to blowing slight smoke most likely oil seal wear - Great for High Flow project or oil seal replacement
$150
R33 GTS-t Series 1.5 Radiator and Surround
Great Condition - No Damage
$80
Trust AIRINX Pod Filter
Almost Brand New - Used for maybe 1000Klm's - Washable Filter
$55
Edited by SLY034
https://www.sau.com.au/forums/topic/257165-garage-sale-r34-r33-bits/
Dimensions of the wing dude?
Overall Width 1335mm
Overall Height 300mm
Width between mounts 840mm
that looks bigger then a normal rb25 turbo?
Its not bigger. Its a standard turbo
R34 GTT Intercooler
R33 GTS-t Turbo
Trust Pod Filter
R34 GTT East Bear Bottom Eyelids
ALL still up for grabs. Dont be scared, make a pm offer. Nothing silly, just want this stuff gone. :(
$80 including postage???
any chips or marks???
They are like new. One very very minor mark on one you cant even notice (im just picky). 80 including? Depending on your location. Whats your postcode?
Edited by SLY034
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
