Same one i have and as far as i know its the same as the C's one, mine is awesome and there is a tutorial on how to fit them in the tutorial section.
You may need to re-use the bush on the end of it as the one i got was really shit and didnt fit properly, just find the part number and call up a nissan dealer for it. The part number is in a thread somewhere
It *looks* the same as a C's, but personally I would only get a genuine C's shifter.
Is it going on an R32 or R33? a 33 one will fit on a 32 with some knowhow but from what I had to do to get the 33 one to fit the RB20 box I doubt a 32 one would fit a 33.
I have a genuine C's fitted to my drag car...when teamed with the PPG dogbox its the ultimate in shifting.
Hey dude just pull out your current shifter and cut about an inch off it, re-weld it and she's all sweet haha :wave: think that's what my car had done to it, you can't tell the difference, mind was laved though...i'll get a pic if you want. pm me if you want it and i'll post it up here.
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
