Hi,
Just curious as to the flow rates per different manufactured oil pump
Tomei?
HKS?
Greddy?
JUN?
Which one is better? Personally would prefer an external pump/dry sump but cant seem to get one at the moment...
Advice appreciated.
Have a look at nitto too. I believe CRD are now using them. Looking at putting one on my new engine as they are much cheaper than the others. Gearing made out of ball bearing steel. They apparently test flow each on a RB26 engine.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
