hi all me again asking yet more questions :uh-huh:
in my everlasting triumph to convince my dad to buy a skyline over a new 2003 model crappy car i have come across an effective way to argue my case.
i can argue how RWD is sooo much better than FWD accept before i do that id actually need to know why. basically i know theres better control and traction but is this only at higher speeds? If you could please write basically the facts of the advantages of RWD over FWD id really appreciate that thanks
No flamers unless u have to :D all bumps welcome :bahaha:
https://www.sau.com.au/forums/topic/25752-fwd-vs-rwd/
  • Replies 47
Bambam's right, FWD is safer to control....in other words...it's harder to get it 'out of control'
definately less prone to spinning out in the wet.
advantages of RWD in the real world? Not much...
That's only if you wanna put your case forward that it corners and handles the way a car should on the race track.
https://www.sau.com.au/forums/topic/25752-fwd-vs-rwd/#findComment-546750
becoz it is a lot more fun
fun=danger
theres better control but not traction
unless u can use yr accleration to turn a corner, let yr tail go out a bit, but can u??
go for 2003 crappy car. u are just a kid, u should learn what a car has to do.:P
https://www.sau.com.au/forums/topic/25752-fwd-vs-rwd/#findComment-546760
here's something to read about....not sure how relevent it is in your situation.
Article on FWD vs. RWD vs. AWD
http://www.toymods.org.au/fwd_rwd_awd.html
https://www.sau.com.au/forums/topic/25752-fwd-vs-rwd/#findComment-546780
my first car was fwd, and guyz at work teased me cauz my engine faced the wrong way ! wen i got into my the skyline, its a different feeling altogether, missed the fwd in the beginning but after having a few exciting moments ;-) i wudnt go back. plus engine faces the right way now.
https://www.sau.com.au/forums/topic/25752-fwd-vs-rwd/#findComment-546848
Things worth trying might be: (dunno how true these are, but if he dosn't know cars might be able to pull it off).
- The fact that there is a driveshaft running down the lenght of the car makes it the chassis stronger and more solid in the event of a crash.
- The only reason front wheel drive cars are made, is because their cheaper
- Skyline brakes are generally very strong (not related to drive but might help).
- If you know how to drive properly (which u obviosly do:)), RWD cars can be easier to controll, understeer badly in a corner in a fwd car, ur stuffed, oversteer can be controlled to an extent.
https://www.sau.com.au/forums/topic/25752-fwd-vs-rwd/#findComment-546868
Drive any car stupidly and you can get into trouble. FWD is definitely a safer drivetrain. RWD is more fun, but basically I think you should follow everyone's advice, stop trying to bullshit your old man and buy a car you want with your own money.
If your old man wants a boring, reliable, economical, cheap to insure FWD car then try and bend him a bit but a skyline would be totally inappropriate for his needs.
https://www.sau.com.au/forums/topic/25752-fwd-vs-rwd/#findComment-546873
RWD : Weight distribution is more balanced than FWD. Braking performance is enhanced. Your tires will wear more evenly.
Cornering is easyer and more responsive. Hard acceleration performance is better than a FWD.
Cornering is better due to power and steering is aplied through separate axles instead of the one. There is no torque steer.
FWD : traction is good during mild acceleration on wet/slippery surfaces. Lighter than a RWD. Better fuel economy. Most FWDs have a small engine. Interior room is enhanced because of no longitudinal driveshaft. Cheaper to afford
If your still after that r34 ive left a link in the other r34 post.
Hope i could help
Skyline boy
https://www.sau.com.au/forums/topic/25752-fwd-vs-rwd/#findComment-546883
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
