Up for grabs is my car.
1 x Black R33 Gts-t 1.5 m-spec
Registration: QLD
Contact: PM me please
Mechanically it is 100% ... Serviced every 5000kms or 3 months which ever came first ... Starts and drives perfectly!!!
Specs as follows
*99 XXX KMs (has had the 100k service done @ 70k)
*Full 3" stainless stell turbo back exhaust with split dump pipe.
*Stealth FMIC
*Red LEDs in dash plus 2 guages in a pillar pod (white on red)
*Heavy Duty Exedy Clutch Kit
*Smoked front indicators
*Low King Springs
*Pioneer H/U
*Pioneer Splits + Rear Fill and 4 channel Amp
Its pretty well just a near stock, reliable car. I only changed things as they needed it. I got a hole in the factory exhaust so i changed it. We live in a hotter climate so i upgraded the cooler to suit et cetera.
Selling as I am full time @ uni now so can't afford to maintain it properly/rego/insurance etc and would rather it go to someone who will look after it.
There is no finance on the car.
The car will need a few touch ups.
PLEASE NOTE
*Issue with air-con relay not switching from hot to cold <--- happy to fix before sale if buyer wishes but will ad invoice ammount to sale ammount.
*Alarm siren not working <--- only just happened haven't had a chance to fix it yet.
*There are two small dings (which I will get pictures of in the next few days) have been quoted $120 to fix,
*The car is registered in QLD but is currently located in Wollongong NSW. The car is being sold as unregistered in NSW or am happy to ship to buyer if they are in QLD. If the buyer would like me to register the car before they purchase it (NSW) I'm sure we can reach an agreement.
ALSO NOTE ALL OF THESE ISSUES HAVE BEEN ACCOUNTED FOR IN THE PRICE I WAS ORIGINALLY GOING TO SELL IT FOR $12500 AND $12000 RESPECTIVELY BUT THOUGHT BETTER TO PRICE IT THIS WAY
PRICE IS AS FOLLOWS THEN $10500 for NSW/other states buyers $11000 for QLD buyer <--- due to 5 months rego and less hassles etc.
MORE PHOTOS TO COME
Edited by BLK33T
https://www.sau.com.au/forums/topic/257642-black-r33-gts-t-15-for-sale/
  • 1 month later...
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
