Hi everyone, it's Terry here, how are you all?
I recently deceided to purchase a set of bodykit for my R34, and I found a factory in China which produces great quality bodykits.
Then I quickly called them to gather some information. I am very impressed about their FB glass kits, and they have more than 1500+ models, and has the ability of producing 300 kits a day. They also export to USA and UK. I had a lot of research in AUS but most of the kits here are too expensive.
Now I am just wondering if any of you guys will be interested in buying a kit for your ride. The kits will be around $450AUD for a full set, which includes a front bar, a pair of side skirts, and a rear bar.
If you guys are after a kit for a specific car model, please post here so I can ask the factory about the availability for that kit.
I need to know how many people are actually interested in buying them before i import, and they are waiting for my answer, so please give me an idea as soon as possible.
Thanks guys!
https://www.sau.com.au/forums/topic/257730-bodykits/
Thanks guys!
What will shipping be? And do they do a kit for S1 Stagea? A website for pics?
https://www.sau.com.au/forums/topic/257730-bodykits/#findComment-4434646
lol, now I know how my missus feels when she says; "am I invisible"?!
Terry did you read my post above?
If this is a group buy, please start a new thread in that section and link it to this one if you like so these posts aren't wasted.
Be also warned that if this is another one of your get rich quick schemes you will be banned........Beer Baron has already spoken to you about this I believe.
https://www.sau.com.au/forums/topic/257730-bodykits/#findComment-4434812
Sorry Sled, I posted a new thread in there already, i read your post , and i was typing in there. Here Im just gathering some information about the kits, i actually haven't started selling yet.
https://www.sau.com.au/forums/topic/257730-bodykits/#findComment-4434850
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
