Thanks for the support of www.omegaxenon.com and his distributor in my country RPM Imports we are going to make a complete rebuild of our RB26 engine..... specs are :
WISECO pistons std
ARGO rods
ACL RACE bearings
ARP bolts
GREEDY head gasket
ATI s pulley
RC 1200cc injectors
GREEDY valves springs
FERREA Ti retainers and locks
FERREA +1mm valves
NISSAN complete gasket set
We will keep using the 264/9.1 Greedy cams, Jun oil pump, powerFC and BorgWarner 72mm turbo.
We our stock rods and pistons we manage to produce 640whp (4 wheels) @ 29lbs and 8,000rpm.....
how much do you think we could obtain now ?
Edited by 95GTR600
WISECO pistons std
ARGO rods
ACL RACE bearings
ARP bolts
GREEDY head gasket
ATI s pulley
RC 1200cc injectors
FERREA +1mm valves
Same turbo, cams etc...the only thing i can see thats going to produce more power is a fresher engine and the valve upgrade. The rest of the list is to make the engine more durable.
All the best with running new PB's with the new set-up.
Edited by DiRTgarage
Do you think that now we could increase the boost up to 40lbs and rev up to 9000 ?
what happened to the old engine?
float oem nissan valve 8500rpm all the way and brake one valve guide but everything else keep in excellent condition. I hope that now we could rev up to 9,000 because the dyno curve shows more hp on higher rpm.
I've got a broken valve guide on an RB26 head too. Which cylinder as it? Mine was cylinder, inlet valve, the last one out of the two.
Are the RC injectors genuine 1200cc in flow? I was looking at gettin them but I did hear reviews that RC Injectors are faulty, high flow injectors that dont seem to work all the time and dont flow their rated amounts + you get a mixed bag of injectors with all different rates from 600-1400cc when you order.
If you can up the boost then you will make more power. IF your peak power is at 8000 - revvin to 9000 is not going to net you more power obviously.
If anything you may be able to make peak power sooner and thus decrease your max RPM.
yes, same inlet valve. :P
RC injectors are fine a lot 2JZ with over 1000whp with no problem from my reading.
the Borg Warner 72 turbo is more efficient at 35psi than 29psi.
anyway we know that 640whp @ 29psi it was not correct we´ve using old stock coils and always an small missfire. now we have updrage coils also.
to DiRTgarage
a) how much is a decent whp on a single 72mm turbo with a 2,600cc engine at 29psi ?
b) do you think it´s crazy up the boost to 40psi ?
Edited by 95GTR600
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
