Hi All,
Well its almost been a year of owning my stag. About this time last year I was hassling Mcnamg for pictures and info of his stag, via PM. I've loved owning the Stagea so much and have made many new friends and gained alot of knowledge on working on cars. First time I ever worked on a car was on the stagea and that was changing the timing belt! and doing 100k service! If your wondering. No this isn't going its time to sell ect ect! The next year will be a bit tighter with cash though as Im going to be a Uni student and not working full time.
'97 s1 silver rsfour, leather, No Spoiler :blink:
In the year I've owned the car ive made the following mods (all i can remember):
  • SAFC2
  • Greedy Profec B spec II
  • Apeix Pod filter
  • Cold air box and Cold air feed
  • Gab Wagon adjusrtable suspension (also tried ohlins)
  • 18" racing hearts
  • Adjustable camber arms
  • Adjustable toe arms
  • 3 1/4" cat back zhorst
  • Hi-flow cat
  • S2 tail lights
  • earthing kit
  • voltage stabliliser
  • HID lights
  • Front Mount IC
  • PWR trans cooler
  • Timer built into alarm
  • Lucas premium front pads
Before I got the car glen had done:
  • Splitfire Coilpacks
  • .8mm gapped platinum plugs
  • clear front and side indicators
  • Alpine headunit and splits
Does anyone have any mods or recommend i do anything in the next few weeks while im still making good $$$. Thinking maybe a gbox service and a shift kit?
https://www.sau.com.au/forums/topic/258240-its-almost-been-a-year/
i think your pritty much spot on with a shift kit, if your retaining the auto. the only other things left are a turbo upgrade, abit more involved ecu/piggyback like an EMU, or a manual converstion.
id also look at doing the fuel pump, the one you have is +10yr old. also an ajustable cam gear may give you a gain but there are other things i'd look at first.
i've heard the walbro 500hp intank ones are good unit, apparently there were some dodgy ebay ones getting around prone to failure but if you get one from a site sponser they are ok. you can get the kit for around $195. im looking into getting a new pump soon aswell.
DUMP FRONT IS THE BEST MOD YOU CAN DO and a highflow cat
JJR stainless dump/front heat wrapped and a catco 3" cat
picked up so much response and midrange, standard dump is almost flat over the wastegate area :thumbsup:
i agree. it just helps the engine and turbo breathe so much more. you can feel staight away how much better the car goes with them.
Just got a qoute on a shift kit, looking at $450 drive in drive out.
Funny you say that. Did the dump/front on a mates and he said he noticed the catback alot more. :S
i did do my cat too...
its a different sort of change, eg, when it coasts for longer when you lift off, less throttle to maintain speed on the fwy, builds boost quicker on the fwy
i then felt a little loss of response when i did my FMIC
upping the boost when i have the motivation to install my EBC.
FWIW I paid 395 drive in/out for my shift kit
ah Im going to grab a cheap $40 adjustable one (s13) and drill the ring connectors to suit :D
fmic looks funneh, should photo it.... no camera tho, soz. sitting under the reo bar - big :) no more spotties and cut the bottom dayz lip off ooops
camera phone and MMS to your e-mail addy
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
