  • Replies 165
took me a few times re reading but now i see what you did there hahahaha
Hahahahaha until I read this I didn't realise there was a cunning stunt performed, awesome :D
BTW, it occured to me that this power figure is the highest I've read about on a Dyno Dynamics running 98 without nitrous.... gotta be up there?
we did my whole engine for $19000AUD...all JUN stuff...it ran 9's on its first outing...the same engine freshened up will go close to 8's on its next outing with new turbo set-up and proper gearbox. This is in a 1460kg GTR on street rubber.
So if I send you au19k and supply nothing, you'll build me a complete reliable RB26/30 4wd engine that I can get back here, install and tune and it'll make enough power to run low 9s in a 1460kg GTR on radials?
And if the answer is no, can you tell me why not?
What hp do you make it that you'd need to do what were tallking about here, around 1000hp?
Rob
Rob
hey hey hey...put your ego back in your pants big boy.
to me a price like that for a bottom end is a little pricey...like i said...good luck to you if you can get people to part with it. Im not the only one in the scene here in Aust who have seen your asking price for a bottom end and have been surprised.
if other people are happy to pay that sort of cash then fine. I have people who whinge about $15000-$20000 quotes for 9 sec turn key engine packages...let alone just bottom ends.
not trying to start a e-war here...not at all. As can be seen by my quote below...but it wasn't enough for you to let go and you still seem upset for some strange reason.
Not at all having a go at you...If you can get people to part with $19000NZD for a bottom end all the best of luck to you Rob. Well Done.
lets get it back on topic shall we.
Edited by DiRTgarage
I'm not upset at all and I don't have an ego, you just make comments to have a little dig which will obviously provoke a response, you pipe up and say you built a complete low 9 sec motor for the same as I charge for a bottom end, its either rubbish or your not giving a fair comparison at all.
You say you feel that my bottom ends/motors are pricey (which is fine, your entitled to your opinion) and then you say you can build a complete low 9 second engine for 19k, and as has happened every single other time I have tried to get the person to compare apples with apples or back up their claim, they shut down or bail out. :down:
I'm not being silly here, you starting with your own donor engine, doing your own work and putting au19k into a motor is a totally different thing to a guy supplying a business absolutly nothing and leaving with a complete low 9 second motor, see my point?
Rob
I agree Rob but you have to remember dirts balls are inflamed and this could be clouding his judgment
Lol, yeah thats probably whats happened.
I'm sure dirt will see where I'm comming from, you have to compare apples with apples or its a waste of time.
Rob
Rob
Donor engine or not RB30 bottom ends here are thrown out by my machine shop and the good ones are only selling for $100 each. Most of the parts are brand new so your arguement there is a very shallow one
ok your bottom end consists of RB30 block and crank = $100
forged pistons = $1500
Argo rods = $1500
Tomei oil pump = $2500
crank girdle/4wd adapter = $1000
Ross balancer = $800
9 litre race sump = $1250
engine bearings = $200
parts total = $8750 and thats being rather fair on some of the prices $19000NZD is around $15000AUD
so you charge $6250 to machine and assemble a bottom end.
Croydon Racing who are known to be quite expensive dont charge that for an entire engine build!
Like i said Rob i find it excessive as do many others but thats not to say what you are doing is wrong...Its like one person finding a $400 pair of running shoes expensive and other finding it a bargain.
Best of luck to you mate. I wasn't having a little 'dig' as you put it...i think my comment i highlighted in my last post would have told you that wasn't my intention. You really did feel a need to defend yourself though didn't you....now where's Boosted when you need him...lol
paul, you raise a valid point about crd.
it is interesting to see how prices vary across workshops that specialise in gtr's - i guess that comes with the package,
i.e. owning a high performance car incurs high performance costs
anyway back on topic.
We did 535kw on 1.7bar 98 BP pump fuel with same turbo kit on a Trust 2.7ltr kit.
on VP109 with 3 more PSI we did 572kw... and as Paul would know i sold it to buy an OS Giken RB30 for more torque...
Good numbers on PUMP fuel. Should do well with GAS and Race fuel, Robs cars have done some good times on the RB30 blocks with stock cranks. I originally discussed my intentions with Rob about purchasing one but decided on giving the more expensive alternative that good friends John and Keir use a try.
All the best and post up your next tunes.
Well done.
Awesome power. Apart from dragging, are you going to track it?
I think what R.I.P.S do is great value.
I got a rb26 rebuild quote from a Certain Really well known Dyno tuning shop in sydney and almost fell off my chair,
$15k AUD, and that gets you no more power than one has to start with.
Lol... subtle
First of all i only brought a block with billit main caps, girdle and sump adaptor fron rob at rips thinking the same as you Paul but let me tell you add all my own parts and machining up and Robs on the money.
rb30 block and crank $100
argo rods $1600
je custom pistons $1500
tomei oil pump $2500
ati dampner $1000
timing belt $100
bearings $250
high volume sump $1500
main studs $350?
new tensioner and idler $250? cant remember exactly
n1 water pump $325
lower timimg belt pulley{ on crank } $90
machining of block consisted of the following:
line bore
deck
bore and hone
grind crank
cryo crank
nitride crank
cryo block
fit new welch plugs
all of the above cost me $2600
That all adds up to $12165aud correct me if im wrong.
Some of you may say you can get parts cheaper but thats what i paid for everything.
Rob sells his 4wd billit main cap bottom end i saw on this thread for under $17000nzd
convert $17000nzd to aud today and you will pay $13693aud for this bottom end right?
Which leaves us with $1528aud difference between robs complete bottom end and my comlete bottom end.
But i havent allowed for a sump adapter so $1528aud for billit main caps and a chromemoly adapter plate
really is DIRT cheap. Have you seen his 4wd billit main cap bottom end?
There is 75 fasteners holding the bottom end together.
So my friends im happy to say that Rob is on the money with his complete bottom ends and as for him doing things 3 times as slow as Paul well i think Rob has run 8.40S and Paul has run 9.90s. :down: ha ha
Again i would like to thank Rob for all his help and wouldnt hesitate recomending him to anyone
Paul
ok..fair call..i was wrong.
no need to be a smartass though...nether of us lowered ourselves to that.
and your times are??? Care to race???
ill send my synchro box and low mounts to Rob and see if he can run 9's with them...lol
Ive actually run 7s but not in a gtr ha ha
I wasnt being a smart ass Paul sorry if i came across like that all im saying is i thought the same as you and most others,that $17000nzd is a bit rich but when you work it out its not really.
I will race as soon as my box is done im not scared ha ha
ahh thats ok...im a bit sore and cranky at the moment...twisted nuts does that to ya!
Mate I can't imagine, I'd say most of us would struggle not being a bit short with people regardless of whether it was deserved or not. Hope it all settles sooner rather than later, wouldn't wish that on anyone :down:
In regards to Rob running a GTR with an H-pattern box down the 1/4, have you seen his first and only effort at running this R34 GTR at the drags?:
Edited by Lithium
what hurts more is having a working car and not being able to drive it...no fun for me.
What box are you running Paul ?
If Rob didn't run marginally quicker than me in a car that had more power than the 240 then id be the 1st to be surprised. It looked good...nice run Wardy.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
