My brother recommended to take it out to improve fuel economy as modifications to the vehicle are currently limited to an FMIC, air pod and turbo-back exh.
After i took out the SAFC2 the car was running perfectly normal, no boost cuts, smooth as silk; it was only once i had changed the plugs that i got the boost-cuts.....
Dude, will all due respect, your brother doesn't know what he's talking about.
  • Replies 44
lol ^
he's right. u need some kind of piggy back to bend the signal, so that you can run more boost without reaching the stock boost cut limits.
also, you said the problem started after you changed your plugs. what gap are the new ones? if they are standard nissan, they will be 1.1mm. you need to use closer to 0.8mm. coz it might well be a spark issue. all power disappears for a second at around 4000 - 5000 rpm when the vct timing changes. thats a standard occurance on skylines with spark issues.
He owned a 450hp R33 gts-t, but I'm not going to argue or say anything more....
Anyway, the SAFC2 can't have anything to do with this as after i removed it the car was still running perfectly fine....
lol ^
sigh :)
The new plugs are the NGK (i think) replacement plugs called platinum laser, and they are gapped at 1.1mm. To change the gap from 1.1mm to 0.8mm can i simply remove the plugs re-gap them and put them back in? Or do i have the buy new plugs?
Dude, I'm not going to slag your brother off, just saying he was wrong. If you don't get somethign for them to tune, then you may well be wasting your money on the dyno tune, as all they'll be able to do is wind back the boost controller till it stops hitting boost cut.
sigh :)
you could do that. but you'll have to be careful because the platinum tips can crack. so use a softish piece of wood to tap the tip against, gradually, till you get it there.
or you could go buy some NGK copper plugs, already gapped to 0.8mm for under $20 for 6. they oftenwork beter anyway, but need to be changed around 10,000kms.
It's fine man, i relaise you're not doing that. It was just that he told me to get the boost controller tuned for a Lo and Hi setting....
Ok i'll give the first option a try and if it becomes too difficult i'll go buy some copper plugs already gapped at 0.8mm.
One other thing, won't the platinum plugs foul quite easily once you start turning the boost up/etc?
Whats boost going up to on your gauge ??
My boost gauge is my boost controller :)
It goes to 0.7 bar on Hi setting, 0.5 bar on Lo setting. So thats 9.8psi on Hi and 7psi on Lo. Boost-cuts on both settings
Fouling is caused by overfueling, which is what will happen now that you have the SAFC removed. If you had the SAFC you could have increased the boost, and then got the SAFC retuned to keep the AFR's all good.
I agree with MonkeyBoy, get the NGK BCP6ES copper plugs, there cheap, come gapped at 0.8mm and means you won't wreck the platinums if that isnt the real problem.
was your bov leaking?
by blocking off a leaky bov you could have increased the boost pressure the engine sees and thus hit boost cut.
We put in the solid BoV gasket the day before i changed the plugs and it was running absolutely normal, just gave the turbo flutter sound....no boost-cuts then....
shouldnt have listed that as one of the things you changed to cause this problem (your first post)
hard to help unless all the info is there
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
