  • Replies 44
Hiflows you're looking at places like MTQ or GCG to make them.
Yes you will make more power, no they aren't cheap (~2kish).
I have a huge hiflow neo on my stag and while it makes good power, it's laggy as hell heh
I bought the stag with the highflow, personally I wouldn't do one myself.
mmm atm i have full zorst, bosch fuel pump, pod , cooler ,clutch , .. think thats bout it ..
i wasnt really looking for heaps of power just a little more .. i didnt want to change to many things i just wanted a bolt on turbo coz my1 is fkd ... but maybe its not the best idea ?????
i think sum guy is selling 1 for $380 + to fit ...
im not to crazy bout getting heaps of power but i was hoping to find out if it will be better ... and i also hav a safc (would it help and wats a good place to go and get that put in my car and tuned )
thanks guys for helping me out ...
cheers
I think your best bet would be to replace with a stock one in good nick. I just sold mine for $320 with lines and it was in good condition so there easy to find for a good price.
If you replaced with a high flow and tuned with the safc and the current mods you probably wouldnt have alot over the stock maybe 20rwkw extra. Is that worth $2300 + install.
Just getting a highflow without other supporting mods is like doing less then half the job. You really need larger injectors,boost controller, z32 afm and a complete replacement ecu ontop of what you have already.
Is that $380 for a stock turbo or high flow, cause thats way to cheap for a high flow?
You probably wouldnt get any more power with a stock turbo replacement and tune on the safc but the response and delivery would be so much better.
Edited by Pattygtst
hiflow for $380?! I doubt it but if it IS actually a hiflow.. and not rooted.. buy it!
Your cheapest option to get you back on the road is another stock turbo.
If you want a bit more power but not heaps then look at a small aftermarket turbo like a 2530 or something.
SAFC will be OK for minor mods but as soon as you start putting bigger turbos on that push a lot more air than stock, you really need a proper EMS.
ohh thanks for the info guys .. thanks for helping me out ...
mmmm still not sure wat to do but now i no wat im looking at ...
well the guy sed it is a ball bearing hi flow for $380 and hes geting it next month ...
i think the place is called KYP or su,thing like that .?????? duz it sound abit sus...wat do u guys thing to good to be tru ?????
id like a lil more power but i dont wonna start sumhing and not finish it ... thanks again guys
Kyp are pretty reliable I think (although he did sell me what was supposed to be an R32 GTSt tailshaft.. I then used that as a template for my custom tailshaft which turned out to be wrong and cost me a few hundred dollars more..)
oh ok then i myt talk to him and see if it really is a hi flow then .. thanks man ..
hay bubba would you no wat else i would hav to do to my car if i was to buy a 2530 turbo like you sed ..
would i need much more mods and dus this turbo bolt on ??how much would i be looking at ??cheers mate
Probably a custom dump pipe, *maybe* a new intake pipe (you may have to fiddle with the piping to get it to meet your current piping).
Turbo will bolt onto the stock manifold but to make use of all the extra air some bigger injectors and some aftermarket management will be needed (and bigger airflow meter depending on what sort of ecu you go for).
Really, you'll be needing bigger injectors and some decent management with a hiflow turbo anyway depending on how much you lean on it..
My Stag has a HUGE hiflow.. it's making ~240awkw @ 12psi but because it's so big it's laggy as hell.. injectors maxed at 15psi so I'm going to get some bigger ones as if I have to live with this laggy turbo it might aswell make all the power it can.. possibly good for 280awkw @ 18psi :D
My point is, anything bigger than standard is going to flow more air, more air means more fuel and better ways to measure the air. You seem to have the bulk of the supporting mods done except for the ECU and injectors.
Also, if you have the cash then a HKS *kit* will have everything required to bolt on but you'll still need injectors and ECU ;)
Edited by bubba
No probs dude, good luck :D
Oh and see if KYP are willing to get that "hiflow" checked out by a turbo specialist.. take it down to MTQ and they'll be able to tell you if it's hiflowed or not.. if it is then $380 is a fkn good price!
Hi flow your own stock turbo. Use pliers to steepen up the angle of the blades. The only difference between the stock turbo on your car and a RB26 is this. It also helps your suspension.
This rates up there with stupidest posts of all time.
You can also retune the ecu by attaching it to an arc welder for a few seconds, for extra power :(
    • WhatsApp+35796370243 Email: [email protected] Telegram: @tesgkm Vásárolj hamis pénzt, és segíts az embereknek szerte a világon elérni céljukat, hogy jó életet élhessenek, és megengedhessék maguknak azt, amit soha nem engedhetnének meg maguknak. Az én pénzemmel. Megvan. Valóra váltom az álmaidat, a világot eléd tárom, a közeli barátaid tisztelnek, az ellenségeid tisztelnek, és a legjobb életet biztosítom neked és a családodnak. hamis euróbankjegyek vásárlása hamis bankjegyek vásárlása Hol lehet hamis pénzt vásárolni? Hol lehet hamis játékpénzt vásárolni? Hol lehet hamis pénzt vásárolni? Valódi kinézetű hamis euróbankjegyek Eladó valódi euróbankjegyek hamis pénz vásárlása online észlelhetetlen hamis pénz vásárlása online hamis pénz vásárlása online az USA-ban valódi hamis pénz vásárlása online hamis pénz vásárlása online hamis golyók vásárlása hol lehet hamis bankjegyeket vásárolni hamis bankjegyek vásárlása online hol lehet hamis 100 dolláros bankjegyet vásárolni hol lehet hamis dollárbankjegyeket vásárolni hol lehet hamis millió dolláros bankjegyeket vásárolni hamis euróbankjegyek vásárlása hamis dollárbankjegyek vásárlása hogyan lehet hamis pénzt szerezni? hamis 20 dolláros bankjegyek hamis bankjegyek ellenőrzése Egy kényelmes otthon nagymértékben javíthatja az életminőséget. A pénz lehetővé teszi, hogy biztonságos, védett és kényelmes lakóteret biztosítson magának és szeretteinek. Milyen jellemzők vagy szolgáltatások tennék álomotthonná a házat?
    • Whatsapp+35796370243 [email protected] Telegram.@tesgkm Buy Counterfeit money and Helping people around the world to achieve their goal to make them have a good life for them to afford what they can never afford With my kind of money. I have. I will make your dreams come true make the world ahead of you make your close friends respect you make your enemies respect you and give the best life for yourself and your family. buy counterfeit euro banknotes buy fake banknotes Where Can I Buy counterfeit money where can i buy fake play money where to buy counterfeit money Real looking counterfeit euro banknotes Real euro banknotes for sale buy counterfeit money online buy undetectable counterfeit money online buy counterfeit money online usa buy real counterfeit money online buy counterfeit money online buy fake balls where to buy counterfeit bills buy fake bills online where to buy fake 100 dollar bill where can i buy fake dollar bills where can i buy fake million dollar bills buy fake euro bills buy fake dollar bills how to get counterfeit money counterfeit 20 dollar bills checking for counterfeit bills Having a comfortable home can greatly improve quality of life. Money can provide the means to afford a safe, secure, and cozy living space for yourself and your loved ones. What features or amenities would make a house feel like a dream home to you?
    • Whatsapp+35796370243 [email protected] Telegram.@tesgkm Money plays a huge role in our lives.Buy counterfeit money. It's needed for basics like food, shelter, clothing, and healthcare. Beyond that, it provides opportunities for education, travel, and personal growth. Financial stability can reduce stress and give people the freedom to pursue their passions. However, it's also important to buy counterfeit money, remember that money  isn't everything, Buy Fake Bills. for relationships, health, and happiness are equally vital. How do you think people can strike a balance between making money and living a fulfilling life? buy counterfeit euro banknotes, buy fake banknotes , Where Can I Buy counterfeit money, where can i buy fake play money, where to buy counterfeit money, Real looking counterfeit euro banknotes, Real euro banknotes for sale, buy counterfeit money online, buy undetectable counterfeit money online, buy counterfeit money online usa, buy real counterfeit money online, buy counterfeit money online, buy fake balls, where to buy counterfeit bill, buy fake bills online, where to buy fake 100 dollar bill, where can i buy fake dollar bills, where can i buy fake million dollar bills, buy fake euro bills, buy fake dollar bills, how to get counterfeit money, counterfeit 20 dollar bills, checking for counterfeit bills, Buy undetectable counterfeit money, buy fake money that looks real online, where can i buy fake money that looks real, where can i get counterfeit money, Money is a necessity! People need it to cover basic expenses like food, shelter, and clothing, as well as for savings, investments, and achieving long-term goals. Financial stability can reduce stress and provide peace of mind. What's your take on financial planning or money management?
    • Whatsapp+35796370243 Email: [email protected] Telegram: @tesgkm Kupujte ponarejen denar in pomagajte ljudem po vsem svetu doseči svoj cilj, da si zagotovijo dobro življenje, da si lahko privoščijo tisto, česar si z mojim denarjem nikoli ne morejo privoščiti. Imam. Uresničil vam bom sanje, ustvaril svet pred vami, naj vas spoštujejo vaši bližnji prijatelji, naj vas spoštujejo vaši sovražniki, in zagotovil vam in vaši družini najboljše življenje. Kupiti ponarejene evrske bankovce Kupit ponarejene bankovce Kje lahko kupim ponarejen denar Kje lahko kupim ponarejen igralni denar Kje kupiti ponarejen denar Pravi ponarejeni evrski bankovci Pravi evrski bankovci naprodaj kupiti ponarejen denar na spletu kupiti nezaznaven ponarejen denar na spletu kupiti ponarejen denar na spletu ZDA kupiti pravi ponarejen denar na spletu kupiti ponarejen denar na spletu kupiti ponarejene kroglice kje kupiti ponarejene bankovce kupiti ponarejene bankovce na spletu kje kupiti ponarejen 100-dolarski bankovec kje lahko kupim ponarejene dolarske bankovce kje lahko kupim ponarejene milijonske dolarske bankovce kupiti ponarejene evrske bankovce kupiti ponarejene dolarske bankovce kako dobiti ponarejen denar ponarejeni 20-dolarski bankovci preverjanje ponarejenih bankovcev Udoben dom lahko močno izboljša kakovost življenja. Denar lahko zagotovi varen, zaščiten in prijeten življenjski prostor za vas in vaše ljubljene. Katere lastnosti ali ugodnosti bi vam hišo naredile kot sanjski dom?
    • Whatsapp +35796370243 Telegram.@tesgkm O dinheiro é uma necessidade! As pessoas precisam dele para cobrir despesas básicas como a alimentação, a habitação e o vestuário, bem como para comprar dinheiro falso para poupar, investir e alcançar objetivos a longo prazo. A estabilidade financeira pode reduzir o stress e proporcionar tranquilidade. O que pensa sobre planeamento financeiro ou gestão financeira? Compre notas falsas online. comprar notas de euro falsas comprar notas falsas Onde posso comprar dinheiro falso? Onde posso comprar dinheiro falso falso? Onde comprar dinheiro falso? Notas de euro falsas com aspeto real Notas de euro reais à venda comprar dinheiro falso online comprar dinheiro falso indetetável online comprar dinheiro falso online EUA comprar dinheiro falso real online comprar dinheiro falso online comprar dinheiro falso online comprar bolas falsas onde comprar nota falsa comprar notas falsas online onde comprar nota falsa de 100 dólares onde posso comprar notas falsas de um dólar? onde posso comprar notas falsas de um milhão de dólares? comprar notas de euro falsas comprar notas falsas de um dólar como obter dinheiro falso? notas falsas de 20 dólares verificando se existem notas falsas A crise atual é realmente difícil, com muitas empresas e negócios a fechar, deixando as pessoas com dificuldades em sobreviver. É um verdadeiro desafio cuidar das famílias e pagar as contas quando as fontes de rendimento estão a diminuir. Que tipo de apoio ou recursos considera que seriam mais úteis para as pessoas afetadas?
