Hey guys I have just had a JD custom plenum made up, however due to a lack of funds have had to sell it. As stated this has never been fitted to my car, and is only two weeks old.
It cost me $820
I am asking $650
PM me with any queries at all.
Cheers.
(this is not my car but what it would look like)
Edited by nelly
https://www.sau.com.au/forums/topic/258518-custom-rb25det-polished-plenum/
