Hey guys,
Just a quick question on installing a boost gauge - just wondering if the place I am putting it in is the correct place or if there is a better hose to T off.
the circle on the left is where I have t'd in to it currently - im pretty sure thats the hose going tot he standard boost gauge. The problem I am having is the boost gauge i bought is very laggy and doesnt meter much above 0 PSI - the factory gauge in the dash goes into positive boost no problem, works fine.
Would the second circle be a better place to T off ? Im pretty sure there are no leaks in the hose, i replaced it with a brand new one.
Also - i have a A/F ratio gauge I want to hook up as well (yeah i know its useless for anythign with a narrow band sensor, and as far as i know the gauge is for narrow band sensors only) but which of the wires from the 02 sensor is the signal ? I assumed the black one was, but it didnt seem to do anythign with the gauge.
Is there a wire I can tap into from the ECU instead ?
cheers
https://www.sau.com.au/forums/topic/258778-quick-gauge-install-question/
personally i wouldn't be teeing anything into the vacuum line for my fuel pressure reg. errno, the one you have tee'd into should be fine. and yes there is a wire at the ecu that you can splice into rather than doing it at the O2 sensor.
check this pdf out. i know its for something different but if you go down to page 2 and look at the ecu pinout pic N4-a, it tells you where the O2 sensor wire is.
http://paulr33.skylinesaustralia.com/diagr...ing_diagram.pdf
Edited by QWK32
is the fuel pressure regulator the hose that ashneel has t'ed into? any idea why the place where I t'd my gauge into would be making my gauge not read must over 0 (apart from a leak - but there shouldnt be a leak as the factory gauge still moves normally)
Thanks for the diagram - that will make it heaps easier to splice into
Gauge could be cactus? Is it reading any vaccum? What type of gauge? New or second hand?
And yeah thats the fuel pressure regulator line.
Edited by Jamesrb25
its a new gauge just a cheap ebay one - it reads vacuum, but its a lot laggier than the factory one and doesnt go into pressure. Ill go straight from where the factory gauge hooks up to the plenum and not T- it in and see if it makes a difference, maybe the sensor is DOA, lol
yes the one that ashneel has pictured is tee'd into the FPR.
does it have a compression fitting on the back of the gauge for the vacuum line? the type with a small copper piece that slides onto the tube before doing it up on the back of the gauge. if it does you may have crushed the tube doing it up too tight.
Yeah give it a shot from there. If not grab someone with a compressor and a blow gun, lenght of hose, and gently increase pressure from compressor and see if it matches what is on your boost gauge. Do this slowly and carefully as you dont want to blow your boost gauge. There will be a few psi drop through the compressor hose, but not much. This will tell you if the gauge is a dud or not atleast.
the sensor is separate from the gauge and has a fitting like the T pieces
ill try not t-ing it and if thats no good ill test it with a compressor thanks guys
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
